Steam Vents
Boston_2
Member Posts: 107
I am replacing all radiator vents.... any suggestions? I have heard the Heat-Maker Verivalve adjustable valves work great and look good.
I'm not a pro, but I've tried a bunch of different brands. Here's my experience:
Hoffman 40 - Works OK, slow venting.
Watts SVA - Works well, adjustable, loud hiss when venting, loud pop when opening and closing. Imported. Inexpensive.
Heat Timer Varivalve - Very fast but adjustable, reasonably quiet. They are not very tall, so condensate can travel up, making gurgling noises and spitting if the valve is set to vent quickly. Expensive. I have one upstairs bedroom that was cold, and the radiator is on the end of a very long branch line at the end of the main. This vent helped it heat up sooner and better.
Gorton - Works well, fast or slow depending on model. Closes and opens gradually, so is not as disturbing as some others. Slower units are fairly quiet. However, size D hisses loudly and flutters before closing. Seems inconstent. Fairly expensive. Good reputation.
Jacobus Maid-O-Mist - My favorite. Similar to Gorton, but seems quieter yet. Interchangeable orifices to adjust speed. Some say that plastic internal parts don't last as long as others. Mine work fine. Inexpensive.
My $.020 -
Jacobus Maid-O-Mist is my favorite too. I've used these for about three years now and they have lasted at least that long so far. They are only $10.00 at Home Depot also!
To help you choose the correct ventind size for your system get the venting capacities chart from this website. It's only about $10 and is worth every penny!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
