purging air of zone
dutch2412
Member Posts: 14
when air is trapped in a zone,how do i purge the air of that zone? ny fr232-w.thanks
depends
That sir; is directly dependent upon the type of delivery system you have I.E. Cast iron radiators, finned baseboard, enclosed convectors. Once we have determined the type of delivery system, we need to examine the piping near the boiler..... Pics may be needed! This sounds like an easy one..... Maybe0 -
purging air of zone
thanks mike. it is ny fr232-w oil fired hot water. the pipe from the furnace on top is hot. after the blue valve it is not. it shuts the boiler down sfter 10 min or so.temp gage reads about 160degr. but pressure is low.the reading on the valve is quad check.thank you.0 -
pictures0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
