BAD BURNING BOILER
ScottMP
ScottMP Member Posts: 5,882
please call a proffesional and have the system thoroughly cleaned and adjusted.
You and your family deserve it.
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • paul_91
    paul_91 Member Posts: 62
    NOT GOOD
    I HAVE A BURNHAM HOT WATER BOILER ABOUT 15 YEARS OLD..IT CONSTANTLY BURNS WITH A YELLOW FLAME AND CARBONIZES WITH WHITE SOOT..ALSO THE PILOT SEEMS A LITTLE TO BIG BOUT 4 INCHES HIGH ..TRIED TO ADJUST IT WITH THE PILOT ADJUSTMENT ON THE GAS VALVE BUT NOTHING HAPPENS..ANYONE HAVE ANY SUGGESTIONS??
  • tim smith
    tim smith Member Posts: 2,898
    time to have it cleaned. Need burners & pilot pulled and cleaned
    brush out heat exchanger and check flue for obstructions. then fire & analyze flue gasses. Good luck
  • Jim_67
    Jim_67 Member Posts: 25
    I that same type problem but with a NEW boiler. The pilot flame was about 7 inches tall and yellow. With a CO detector in the vent connectors it was producing almost 500 ppm of carbon monoxide.
    The entire pilot assembly was replaced and that took care of the CO. The pilot flame was less than a inch and the CO reading went down to 22 ppm.
