M80 Munchkin Spark electrode FO9
Lots of info that may help. Some that won't
New install of a new 2005 unit I have had until ready for installation. I am constantly getting a FO9 error code due to no ignition. I can pull the spark electrode and get spark, but unable to get spark once it is replaced into the unit. The gasket was damaged from the factory, but I am curious if there have been ongoing issues with earlier Munchkin spark electrodes and if the design has been changed from 2005. Any help will be greatly appreciated. Thanks Jim0 -
Thanks MPF, but nothing there that helped. HT tech said clean rectification chamber, did and yet still no spark while in chamber. If I take the spark electrode out of the chamber it is sparking, but will not when reinstalled.
Again this is a new install...never been fired, Have altered gas pressure LP several times as well as on gas valve. Anybody got a clue? Jim0 -
Chances are,,,
it's shorting out on something, frame maybe. Possibly cracked ceramic? I've installed exactly one Munchkin and it fired right up and has continued to do so. I've yet to take it apart to see exactly what makes it tick. Sorry I'm not more help.0 -
F09
Make sure the burner door refractory is not touching the spark electrode.0 -
You may not be able to see the spark now. Did you use the conversion kit?0 -
HT,
Came with LP conversion kit and made changes as required though unable to take CO readings since it has yet to fire up. After further trouble shooting I suspect the Dungs gas valve is not opening. I have pulled the spark electrode partially out and restarted the boiler to see if I can hear the electrode sparking,,,which I can, but I am not getting gas into the chamber. As stated I have adjusted the LP on serveral occassions as well as the gas inflow setting on the Dungs valve. Nothing...therefore I am concluding it is a defective gas valve. Sound logical? Jim0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
