On-Line plumbing supplies
Mike C._4
Member Posts: 56
I used www.houseneeds.com for some of my solar supplies like the ones you need. I have never seen a check valve that has a "manual" mode for back flow in a solar system.I believe the flo-checks used in boiler systmes have that capability but I think they are only available in steel-not brass. You may want to just put in a drain valve for that purpose. That's what I did.
Is there an on-line plumbing supply house out there? I'm looking to purchase a sweat type 3/4" in line thermometer Dry-well to monitor the hot water in my solar closed loop hot water system. It's the type that the well sweats into a 3/4" Tee and the thermometer slides into the well. I'm also looking for a 3/4" sweat type spring loaded check valve which would have a manual override which would allow me to open it if I needed to drain my entire loop. The spring loaded check would stop any thermal syphoning action. Thanks for any help.0 -
Everything
is available on-line...even love, if you can call it that.
I am not going to recommend any particular site, but yes, you can find just about anything on line.0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
