How can I determine if my steam is dry or not?
Mad Dog_2
Member Posts: 8,570
kinda like worrying about a stubbed toe when you have a major health issue. Until you are ready to make that job right, don't touch it!@. Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=299&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
The boiler leaks on the attached photo have been fixed. Note the horrible plumbing job.
I obtained quoted to rebuild the piping to the main, bit the cost is just too great to afford.
Would there be a tangible benefit to properly re-pipe the risers from the boiler so that the mains are at least fed properly from above the Hartford Loop? (I know the Victaulic joints all inappropriate, but for now, they work). This is simply a matter of spending a little now if it can save energy.
On a positive note, the system works and there is no banging or knocking. So unless we can get more efficiency, we will keep things as they are.
SteveSteve from Denver, CO0 -
Thanks for the feedback. It kills me to look at the way it was piped. But connections to big 4-inch pipes and a ten year old boiler means I guess we'll just wait it out a bit longer.0 -
looks like those doors have been pretty hot. are you still getting roll-out?
TimJust a guy running some pipes.0
- 120 Geothermal
- 169 Indoor-Air Quality
