Removing old stem boiler
Blackmajah
Member Posts: 12
I have an old steam boiler made of steel. If I could do the demolition I could save alot. How thick would the steel walls be? What equipment would I need to do this?
Rob
Rob
Steel would require a 7" grinder and dozens of steel cutting wheels. A sawzall works OK but both are somewhat slow-going. If you have ventilation, a oxy-acetylene torch is best...if cast iron, sledge it and bust it up.
TimJust a guy running some pipes.0 -
boiler demolition
Tim
The boiler is an American Standard (Kewanee Boiler Division) Round Type R boiler Series 10X, no. 1735.
Could the walls be more than 1/8 inch , 1/4 inch thick? What about a circular metal cutting saw? How experienced do you need to be to use an oxy-acetelene torch?
Rob0 -
Call
around there are many companies ,that remove boilers. They will save you a lot of aggravation ,won't make a mess. And do it pretty cheap0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
