radiator nipples
Heatman_2
Member Posts: 65
100 year old cast iron radiators, trying to add TRV's. Does anyone have a trick to get the old nipples out when the inner spud nipples just snap off. Most are 1.5" size pipes.
I cut the nut off with a buzz grinder, insert my spud wrench, and use a pipe wrench. The spud wrench stops the brass tailpiece from collapsing and you can usually get enough torque to get it to spin out...also spray on some pipe-break free stuff...
TimJust a guy running some pipes.0 -
BTW, my mom is from Mitchellville and my uncle owns Vignovich trucking out of Madrid...lots of IA ties...
Rad nipples
Also if nipples break off or wrench won't do it, cut a small pie shaped piece out with a sawzall and very fine tooth blade. Take out piece and rest can be extracted with a hammer and chisel.Careful not to cut into the radiator threads. Good luck.0 -
Easiest way as I have done many times.0
- 120 Geothermal
