flow rates for radiant
ed m
Member Posts: 65
trying to see what to set my flow rates on manifold, 5 loops 1/2 pex at approx. 250ft per loop. for radiant in floor heat off an indirect.
thanks
eddie
thanks
eddie
Some variables need to be nailed down.
Hi Eddie,
It all starts with your heat loss (of course!), but also your floor covering R-value and net radiant area. Also, is it a slab, sub-floor panels, what now?
A short answer would say that 0.5 to 0.75 GPM per circuit is a reasonable flow rate range, but what temperature drop?
Some designers prefer a 10 degree temperature drop to reduce temperature contrast, some go 20 and have no issues.
By the basis I give above, you could supply between 18,750 and 37,500 BTUH and if a maximum density of 30 BTUH per SF, 625 to 1,250 SF of radiated floor area.
Too much of a range to give you the real answer which is probably something else...0 -
Hey Eddie,
Here is a Radiant Panel Worksheet I made for this purpose.
Might help you..0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
