EK2 System
Ken Field
Member Posts: 123
and if I may offer a couple of suggestions, point the tees in your primary/secondary loop up. The oxides and crap from the old system will not make it back to the heat exchanger and boiler nearly as much if you do. Also, I would have suggested replacement of the oil line from the wall to the Tigerloop. I'm not being critical, only trying to help. Your work looks great.
Ken F
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=418&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Ken F
This system was in Lloyd Neck , NY
Real beautiful peninsula connected to L.I. on the north coast . I heard the customer was burning almost 2500 gallons a season . Alot of room for improvement there .0 -
EK2 with the aquabooster
The job was speced with 2 injection zones , 5 zones total . The post purge functionality of the boiler required a whole bunch more wiring and controls . But it all worked out in the end . Now I'm ready for my first beer0 -
Thanks Ken
for the compliment and suggestions . I was wondering why all the diagrams showed the tees pointing up . Sediment shouldn't be a problem though . We added cleaner on the 1st day and on the 2nd day we drained it ( a few sweat leaks ), added more cleaner and purged the system with hot water . Normally we try to replace the oil line but we're going back in a few weeks to install a new tank .0 -
nice job!
its like night and day differance there..well done.
Thanks Gerry
There were 4 of us for the 1st day , and me and Paul went back to wrap it up . The wiring took up a good chunk of the 2nd day . And finding a suitable spot to run the fresh air vent out of a huge home and keep the length of pipe within specs was a chore , but Paul figured out a way .0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
