Taco pump sizing
Dan Sedens
Member Posts: 48
I believe it calls for a 0012 or a 0014. No specs here just going by memory.
Definitely could be wrong.
Dan
Dan
Taco pump sizing
Have a Lochinvar Knight KN-105 with a Weil McLain (Triangle Tube)60 gallon indirect.The main header is primary/secondary piping.The domestic comes off the boiler before the header.The boiler is 1" supply and return,the domestic is 1-1/4".What size do you think the Taco circ should be?It currently has a 0010.
Thanks,Scott0 -
Grundfos UPS26-99
better pump, handles all the pumps you mentioned
EASY
EASY
EASY
Multispeed pumps are way better than single speed.0
- 114 Geothermal
