wood boiler again
Ray_20
Member Posts: 5
First question was not clear. re:http://www.centralboiler.com/media/CBBrochure.pdf page 14 existing boiler. I'm only concerned with the piping in the wraparound loop - that is between the tee at the top (supply) and bottom (return). All piping after the supply tee and before the return tee is existing and code compliant. System has 3 zone valves. The existing boiler has a domestic coil with no priority control or outdoor reset. Central Boiler told me that the size of the piping in the wraparound loop should be 1 1/4", as that is the size of the heat exchanger tappings. The existing supply and return tees and manifolds are 1 1/4". When the supply circ pumps to the zone/s will the wraparound loop cause any problems getting max temp water to the zone/s? Should the circs be the same head, gpm, speed,etc? Some thoughts - monoflow tees, check valves, wraparound loop piping smaller than manifolds. Has anyone done this and does it work as shown in drawing? Thanks
Ray
Ray
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
