water leak around boiler
Timco
Member Posts: 3,040
If you have iso valves on supply & return, kill power, set pressure to 20, kill auto-fill, and see if the boiler holds pressure.
Tim
Tim
I have a 20 year old weil mclain and a amthrol hot water maker.so the boiler runs year round.now when i first turned my heat on for the season,i notice water at the right corner by the boiler drain.i see nothing obvious and pressures seem fine.short of pulling covers off any suggestions0 -
are you thinking the boiler is cracked?0 -
Great place to start checking...Just a guy running some pipes.0
- 86.7K THE MAIN WALL
- 54 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
