PH Test Equipment
Paul LeGron
Paul LeGron Member Posts: 11
What equiptment is needed to check the PH level on a system with glyco in it. How do you do it, and how often should be done? Thanks for your input and help.
Paul LeGron
LeGron Plbg.
  • Plain old...
    litmus paper from any chemistry supply company will do the trick. 7.0 or slightly above I believe is the correct PH.
    hot_rod Member Posts: 24,425
    stick meter
    These battery operated stick meters are handy if you do a lot of testing. This Hach was purchased at Graingers. The red refractometer is a good tool for glycol testing PG or EG.
    Or one of these solar test kits. It has the ph, glycol tester, point and shoot temperature, and a bunch of other cool tools for glycol and solar testing and maintenance.
    hr
  • lee_7
    lee_7 Member Posts: 457
    try a pool supply store. They have plenty of test kits.
  • Paul LeGron
    Thanks alot
    Thank you for your input
    Paul
  • Paul LeGron
    Very Impressive Equipment
    Thanks for the pictures. I will look into purchasing this equipment. How often should a test be made on a system?
    Paul
