replacement sizing
ctjomac
Member Posts: 52
I have a one pipe steam boiler, H.B. Smith Oil Boiler, installed in the early 50's. (4 sections) Plate reads 405 sq. ft. steam and 96.800 water and 1.30 gph fuel. I have a 1.25 gph nozzle in it. I would like to consider an upgrade, but need some professional advice. The boiler I have now runs fine, but sucks fuel like it's free. I have an opportunity to buy a used weil mclain that was bought new in 2000 and was in service for 4 years until they went to gas. This weil mclain though only has 3 sections and the plate reads 358 sq. ft. steam, 86,000 water, Gold SGO-3 oil. My house is all original, never added on, but I don't want to buy it if the pros here think it may be too small. Any advise is greatly appreciated, but no I can't afford to buy a new one this year, just thought that upgrading from 1950 to 2000 might save me some fuel and gain some efficiency. Thanks Much, Joe
I posted earlier and SteamHead and TimCo asked for radiation totals, so I found out that I have 94,620 EDR hooked to my current boiler.
So, should I pursue this other boiler or am I just dreaming?
I would check your EDR again
I assume that your 94,620 "EDR" figure really means "BTUH". if so, your nameplate might also say, "394 Square Feet EDR" or some-such.
If this is the case, the W-M you have would be under-sized.
I am not about to suggest that you remove sections from radiators or replace them with smaller ones, because I have no idea what your current heat loss happens to be. If you insulated and added new windows, sealed the place up, you have a shot at doing that.
Otherwise, you are looking at getting the right size boiler.
Start with your radiation and let's go from there.0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
