What Size Oil Line?
oil-2-4-6-gas
Member Posts: 641
use the smallest line needed for the --application --the smaller the line the less oil the line has to move and the more chance of it not gelling -- i have A Suggestion for you --insulate your oil line --put some kind of windbreak around the tank -or the all-in 1 tank enclosure-checkout www.oilstoragesolutions.com for examples ----its easier to move oil through the smallest line that would work for the run of tubing and gph of your burner -- if you put a windbreak,correct size line,pitch your oil tank,clean-out any water in the tank,----THE IDEAL way to go with out door tanks are run single pipe oil line to a tiger loop - with the tank in an enclosure --every couple years have the tank checked for water -and dealt with--if you do those things you wont have a problem -i work in Westchester county and have fixed a handful of problem systems following those guidlines --
What Size Oil Line?
Hello. I'm installing an above ground 275G. tank outdoors on Long Island, NY. I was planning on using 3/8" copper tubing for delivery to burner, but I have seen some outdoor installations using 1/2". Would the larger tubing be a benefit in extremely cold weather? Is there any other reason to use large tubing? Thanks, jdl0 -
what is the run....
length to the burner and what oil burner are you using?0 -
are you going to put the suction line from the bottom of the tank or through the top ? is the line going to buried or in any cement ?? Long Island is not consider extreme cold for #2 oil -- if it were then it would be commonplace in your area to burn K-1 in the winter0 -
3/8
this should be fine.Most times i have went on a supposed gelling it's water.(well ice )Be sure you use a flip cap. Also all plugs tight.I know you hear of condensation buttt i fell most water comes from snow on top outside tanks ,melts and if plugs finger are tight the water follows the threads. royboy0 -
my thought
hope this helps0 -
What Size Oil Line?
Beckett AFG and the run is about 25ft.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
