cold basement rads
John_213
John_213 Member Posts: 1
Just installed a new luna/baxi boiler in a very small bungalow.The basement rads now do not heat up.We only drained the main floor rads and the primary diverter tee loop.Basement rads only have 1 rad valve so I'm only able to purge 1 of the 2 lines to the rad.Any tricks of the trade out there that have worked for you guys other than adding another valve.Thanks in advance
  • Timco
    Timco Member Posts: 3,040
    Were they on their own zone / pump before? Now? Either air bound or no circulation.
    Tim
  • Brad White_200
    Brad White_200 Member Posts: 148
    And, Or
    is the piping a monoflow loop and how well did they work before?
  • basemeant rads aren't heating
    when bleeding or purging the basemeant system make sure the water is cold because hot water dosen't want to go down (heat rises) -- puff back
