Fryrite Pro W.C. test.
kev
Member Posts: 100
Can the draft feature on this analyzer be used to test inches of water column when setting up gas valves on burners? The draft reading is read in positive numbers. Would the negative reading be accurate to use?
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
