Winterizing a hydronic system
Bob_98
Member Posts: 8
Would like any input into winterizing a building that will be without heat this year as it is unoccupide. It is a Hot water baseboard convector system with runs underground. So just draining is not going to remove all the water. We are a heating contractor who has never attempted this and would like to help out a good customer.
Air compressor, blow out all zones and boiler. Just did my house upstate ny, kripplebush. Gets real cold up there.0 -
Got to agree
If you blow out each run seperately as you would when you fill and let it run for quite a while, they should be dry. No different than irrigation guys do every winter here in the frozen North. You'll want to have a good compressor. I'm not a fan of shutting down a system if it's a home. Hope the owner understands the other implications of moisture, frost, etc. that can do lots of damage to the structure itself.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
