Biofuel concerns
Michael Wagoner_2
Member Posts: 6
We're installing quite a few system 2000 boilers, and a few people have asked us to make it compatible for 100% homemade biofuel. is there something other than installing their biofuel flexible oil line that we need to do? do the copper lines need to be run in black, or is copper still ok? do the gaskets on the oil filters need to be different?
B100 w/EK
At the present time the Suntec fuel pumps shipped on Beckett and Carlin burners are listed for only up to B5. The gaskets on the Smart Filter cartridges are listed for up to B20.
During testing by others it was found that copper oil lines could be an issue. Likewise, steel nozzles, as opposed to brass, have been recommended.
It should be mentioned to these homeowners that if there is a problem due to using B100 no burner manufacturer will take any responsibility since the burners are not listed for it.0 -
Thank you.
So would all the firomatic valves, etc also have to be worked out to be steel in some way?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 919 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
