Splitting a radiator
Paul_58
Member Posts: 18
I may attempt to reduce a thin-tube style radiator from 16 to 8 sections. I assume I will need both end sections when I reconstruct the radiator. Is this correct? Thanks.
Yes!
otherwise it would have no legs, and no place to screw the pipe in.
The ends usually have all RH threads so standard bushings will fit.
TimJust a guy running some pipes.0 -
Doh!
The legs!!! I'm done for the night, thanks!0 -
Anybody here ever succesfully split an old Rococco radiator
and put back together, just wunderin. I have thought of trying sometime but of course then the thought vanished. Tim0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
