Outdoor wood boiler
Brad White_200
Member Posts: 148
a simplified diagram to illustrate general system concepts, there is no expansion tank nor relief valve for one thing.
They also show a circulator and zone valve in series for a single heating element, kind of redundant.
They probably should qualify the drawings that they are diagrammatic only and do not necessarily indicate code-required appurtenances and to consult local professionals before installing...
Absent that and I am sure a few other things, I would not beat them up too badly. For example, if you have a tile floor, they show wood so obviously the product would not work in your house. :)
Outdoor wood boiler
Re:www.centralboiler.com/media/CCBrochure.pdf
page 14 Existing boiler pressurized
Something seems wrong with this piping. What is missing?
Thanks0 -
In that drawing
(If we are looking at the same thing) it's hard to see the HX (shsded). These boilers are for use on open systems, not meant to be pressurized, not ASME rated as a pressure vessel...0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
