Maine code question
Jim Franklin
Member Posts: 170
I recently heard that in Maine they don't want the automatic feeder installed above the LWCO. Their theory is, if a boiler leaks, that the feeder will satify the LWCO into believeing that there is no leak occuring.
Take into consideration that most LWCO's are located just above the boiler in the supply, while the feeder is usually located between the Xtank and air eliminator just above the LWCO.
Any thoughts?
thanks
Any thoughts?
thanks
code
There are codes in Maine?
I quess I should add that I am joking.0 -
Not a code here! Believe none of what you hear and only half of what you see!!!
More Codes
than you can probably handle.
Jed0 -
Maine Cods
I hear the cods are scarce in Maine more all the time.0 -
just the oposite....
Maine has been adding more and more regulation of everything the last 10 yrs....0 -
The state government in Maine
is 18% larger than the national average. It has enlarged beyond proportion for the population of 1.3 million (one area code).0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 67 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
