Boiler by-pass piping
![[Deleted User]](https://secure.gravatar.com/avatar/3e861c724cfde079b1abdf0ff6e3df25/?default=https%3A%2F%2Fvanillicon.com%2Ff396eddb8a590823a17350f756613f15_200.png&rating=g&size=200)
[Deleted User]
Hi guys. Ineed your help to jog my memory.
I'm told i'm replacing a large residental h/w boiler (300tbtu) next week. Only thing I found out about the job is the approx. rating, it has big (?) pipe, and 5 circs with one having 3 zone valves all on the return, and not to be moved to the supply. I'm thinking I need to at least install a by-pass between supply and return. But i'm not sure of just placing a tee between the circs and the boiler and piping ( what size?) to a tee into the supply will work properly.
Mike
Mike
5 circs and zone valves? You should really straighten this install out and get all the zones in order. Sounds like a mess. Hard to say if you need boiler protection bypass or diff press bypass. I really try not to reconnect to all the mess...
TimJust a guy running some pipes.0 -
married
Agree with Tim. Who knows what problems are lurking on this job before you get there. Ignore the visible signs or potential problems and you will be married to them.
In a few weeks you may hear - "Everything worked fine before you put in this new boiler thing. You must have done or changed something".
Know what your getting into.
My $.02
Glenn0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
