size circulating pump to use
john_181
Member Posts: 93
I was on here last fall and you guys were great helping me get my old boiler up and running. I do have a question. My circulation pump is a B&G serries 100 and the inlet and outlet pipes are 1" in size contected to my building pipes which are 2" in size. Is this OK or should i have a pump that pushes more flow??
Other info:
boiler is 430,000 BTU
27 radiators
former gravity system
large heat supply lines 3"
return lines 2"
Thank you
Other info:
27 radiators
return lines 2"
Thank you
How many square feet (E.D.R.)
of radiation do you have?
good question
each radiator is 4 row per section and there are 20 sections. 2.5 feet high0 -
Take some pics
and post them here. We should be able to ID them. Your system originally circulated by gravity, so we have to be careful not to over-pump it.
Piping
It should be on primary/secondary piping.0 -
Overpump?
What are you referring to? I assume you mean the flow rate would be so high as to reduce his Delta T ? Or, the velocity of the water would be so high, that he would create excessive turbulence, noise and air?
What is the downside you are referring to?
Glenn0 -
Even if it's just one big zone?
TimJust a guy running some pipes.0 -
I agree with Tony on P/S
The suggestion to use Primary/Secondary is to decouple what is probably an over-sized boiler for the current load. Even if not, one would want to keep the (CI) boiler hotter to avoid condensation.
Using P/S allows the radiation side almost total reset ability, down to nearly room temperature.
The size of the system and zone composition is not relevant to the P/S question, not that zoning is something to be avoided.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
