service heads up...
Unknown
Member
I appreciate the heads up.
Noel
Noel
service heads up...
On many boilers with spark ignition, there is a 1k resistor in the right angle rubber spark connector, same goes for some of the flame sensors, if you have your finger around the angle part when you pull it off, there is a good change you will snap the neck of the resistor wire going into the connector so please pull it from the bottom of the boot, this happened to me on a knight boiler, I had had a bad board and in diagnosing back and forth I must have broken the resistor and I fried the replacement board because sparking into an open secondary, kills the primary drive transistors, just like open spark plug wire in cars is the primary cause of ignition module failures, mechanics know, that if the module dies, they need to change the coils and wires or it will come right back
Brooklyn ny dirty gas!!!
If you are in an area where there is a lot of construction going on and you get ignition lockouts and a pressure test shows significant drop on open, undo the 4 hex cap screws going to the gas valve inlet block, and pull it off, then clean that yellow powder off the inlet screen with a soft bristle tooth brush and vac cleaner this will manifest itself in weird ways, like a steam boiler with a full but quiet fire that doesnt produce steam, and lock-outs on modcons cast iron hydronic boilers will mask this problem for a long time as they will fire and heat the water enough for all but the coldest days0 -
Same Here.......
......thanks
Noel are you still with SlanFin ?There was an error rendering this rich post.
No
I'm back home in NH at Laars Heating Systems now.
Noel0 -
Hey, Noel.
Thanks again for helping me out last week.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
My pleasure
I hope we get to see each other at another ugly sometime.
Noel0
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
