Flow Control Flange
MikeyB
Member Posts: 696
Would anybody know if I would be able to use a B&G Check-Trol Isolation Flow Control Flange w/a Taco 007 Circulator? Thanks for your help guys
Yes
The are a standard 2-bolt flange, to which most if not all circulators in that range adhere.0 -
Thanks Brad, this will save me alot of work.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
