Number of 1/2 pex radiant loops can be run off 3/4 copper pipe
ed m
Member Posts: 65
need to run 1200 ft of 1/2 pex for radiant heat, a new extentsion. there was radiant in the floor,demoed it all now need to run 5- 250 ft loops do not know if the existing 3/4 manifold in crawl space can handle it. radiant is off a 30 gal indirect.
thanks eddie
thanks eddie
Heat loss
What's your heat loss for the area Eddie?0 -
You're ok
You could actually run up to six 1/2" pex loops off of that 3/4" copper if you needed to.0 -
It really depends on the GPM required for the area/loops and proper selection of circulator with all items considered.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
