Hydrotherm help old HC-180
George_39
Member Posts: 2
Hi, Have a HC-180 Hydrotherm Boiler, Promlem: Burners not firing. Tested the following. Gas pressure good. All four Honeywell zones turn on the pump. Millivolt pilot keep the pilot on. jumped out the thermal at the back panel and the boiler fired once. Took jump off and tested again no fire. Jumped out Th & Tr and boiler fired. Boiler has aquastat relay checked for 110 volt, ok Low Voltage side has 24 Volt. Checked with Hydeotherm no trouble shooting manual and no help I guess to old? Gas valve should be good if it fires when jump, Right? I was thinking about the zone valve end switch but all 4 cant be bad. Need help...
Old HC-180 Hydrotherm Boiler
Hi, Have a HC-180 Hydrotherm Boiler, Problem: Burners not firing. Tested the following. Gas pressure good. All four Honeywell zones turn on the pump. Millivolt pilot keep the pilot on. jumped out the thermal at the back panel and the boiler fired once. Took jump off and tested again no fire. Jumped out Th & Tr and boiler fired. Boiler has aquastat relay checked for 110 volt, ok Low Voltage side has 24 Volt. Checked with Hydeotherm no trouble shooting manual and no help I guess to old? Gas valve should be good if it fires when jump, Right? I was thinking about the zone valve end switch but all 4 cant be bad. Need help...0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
