Tekmar Stats
bobbyg_16
bobbyg_16 Member Posts: 11
looks like these people are the rep for that area.
www.fiainc.com
you might give them a call.
  • ChasMan
    ChasMan Member Posts: 472
    Tekmar 510's
    I bought a couple of TEKMAR 510's I have a minor issue with one and a major issue with another.
    The minor issue is that on Friday, schedules that overlap midnight do not work. They cut off unless you set the schedule 20 minutes before or after midnight. It works ok on the other days of the week.
    My Major issue with the other one is that the Time menu will not show up. Its almost like it is non-programmable yet it is a 510 and not a 507. It looks like it was flashed with 507 software or something.
    Does anyone know of the sequence to clear these? Ie, reset to factory?
    Does anyone have a tech support contact for Connecticut area?
  • support
    you can call tekmar directly too, (250)545-7749 and ask for tech support, those guys are great.
  • ChasMan
    Ill give them a call. I want to get it sorted, I think they have a small bug in their firmware. I did get my major issue figured out. It seems you can not get to the time menu unless you first set a schedule either 2 or 4 times a day. As soon as you do that the time menu is available.
