Ghost Heat
TJ_5
Member Posts: 71
Have a system, installed for aprox 2 years, a Burhnam MPO with 7 active zones, 6 heat and an indirect. all controlled with taco 00R Circs (internal check) and SR504's. At end of last heat season one zone the #7 developed a ghost heat, first thought was check shot, confirmed by isolating zone(I thought) Let system run for end of season, getting the unit ready for this season replaced the CIrc, with a new 000r (3speed) set on low. Client called same problem back. My thought is to have client let boiler go cold overnight and bring the zones back on one at a time to locate a zone that may be causing a siphon action on that zone. I hate to think a second check valve shot on a circ. Any Ideas???
A pic of the supply & return manifolds would help. Could be a stuck swing check on the returns. (opposite the circs) Sounds like something failed especially if this has not always been happening.
TimJust a guy running some pipes.0 -
IFC
IFC's are not reccomended for use on indirects. This may or my not be related to your problem, just talking outloud here.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
