Heatmaker Replacement Boiler
narcaparbebra
Member Posts: 32
I am looking to replace my 18 year old heatmaker (heating coil ruptured) boiler. The exact replacement would be a LAARRS endurance boiler but have not heard pleasant things.
I started some research and came accross the Baxi Luna comfort 3 with the Modullio tank. Is this a good reliable boiler? I don't know that I would benefit from the condensing boilers which typically runs 700 to 800 more.
I have two more heatmakers in the tenants apartments that run fine but will probably look to replace those too very soon. Any suggestions?
Baxi
I install a Baxi's as a good replacement to the heatmakers. The only thing to watch for is the 3/4 inch gas line (lp) that is needed for the Baxi. Most of the heatmakers around here were either 1/2od or 5/8od. If I were you I would consider investing in the HT380 over the Luna 3. I installed one last week and was able to operate 4 showers continuously on the HT380.It was when I turned on a lav faucet that the pressure and temperature started to drop out. I was quite impressed with that. It would probably cost you less than the Luna and Modulo.0 -
Thanks Bob. Are they reliable?0 -
Reliable
It's all in the installation. If you follow the installation and set up instructions, they are very reliable. I have been involved with Baxi for about 5 years now and have found them to be very reliable. I really like the HT380 boiler now that I have seen the DHW output.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
