Does anyone repair wood furnaces in MO?
Charles_10
Member Posts: 3
... that previous occupants didn't get CO poisoning!
[IMG]http://i34.tinypic.com/2qx96cz.jpg[/IMG]
[IMG]http://i36.tinypic.com/2wp1gsj.jpg[/IMG]
[IMG]http://i35.tinypic.com/1z2izxs.jpg[/IMG]
this explains the smoke stains on the wall above the registers closest to the furnace.
Front ends of heat exchanger tubes rusted
I just moved into my rental house (long story :P) which has a propane and a wood furnace, forced hot air. They are both connected to the ducting with a flap to select one or the other.
Unfortunately the wood furnace had never been properly maintained, and small leaks of hot exhaust gases over time have corroded the ends of the heat exchanger tubes to the point where the cover (cleanout) plates will not seal. In fact somebody tried to use RTV previously!
So I am trying to find a source of new parts (at this point I'd rather just replace the heat exchanger than spend hours and $$$ having custom welding/fabrication done). I live in a rural area (West Plains, MO) and can't locate anyone who can help.
Any ideas welcome. In the meantime, guess I'll be heating with the propane!
-Charles
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
