Curtains
Betty_4
Betty_4 Member Posts: 1
The curtains are on each side of the radiator touching the sides.
Thanks........
  • Betty_3
    Betty_3 Member Posts: 1
    Curtains
    Hello,
    Would curtains touching a steam radiator cause any problems??
    I have measured the radiator at about 180 degrees which I believe is below the point at which the fabrics would face problems.
    Any thoughts gentlemen?
    My thanks.....
  • Gordy
    Gordy Member Posts: 9,546
    Material
    Not to say it is a hazard. But depending on the material the curtains are made of, it could promote accelerated deteration of the material. Are the curtains in direct contact, hanging above the radiators, or when closed hanging in front of the radiators which would then block heat transfer to the room.
    Gordy
