Draining a forced hot water zone........
Lil-Roc
Member Posts: 50
How do you get a steam system to do hot water on the third floor and have steam below it? I have seen it where the hot water side is below the boiler using the condensate return like for a basement but this doesn't sound right. The only way I could think of is a that you must have a separate heat exchanger correct?
I have 2 zoned heat, one zone is steam heat and the other is forced hot water. I would like shut off the forced hot water zone this winter as it's on the 3rd floor of the house which is not really used. Do I have to drain the system so it doesn't freeze or can I just shut it off? If I have to drain it is there anything else I need to do on top of that?0 -
If you suspect it will freeze in the area to be left off, it must be drained. Old rads & circulators & other parts do not like to be dry, so leave water in the loop if possible.
TimJust a guy running some pipes.0 -
Yes...
FHW off DHW coil in steamer... My house had been done like that, my cats like it better now that I'm all FHW... they can sleep on the rads now!0 -
They ran forced hot water baseboards for the 3rd floor off the bottom of the boiler. I'm not a heat person so I don't know the specifics of it, but any heat guy that has seen thought it was clever the way it was done.0 -
Tim, what do you mean by "leave water in the loop if possible"? What is "the loop"?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
