B & G 100
Reynz_2
Member Posts: 98
Tim,. Will the Grundfos UPS1558fc replacement provide low head pressure and high volume like the B & G 100?
Motor Change
Well, after 5 long years it seems that my trusty old B & G 100 needs to be repaired to replaced.... What are my options...
Is it worth trying to have it repaired or do you just replace them? Are they easy to replace?0 -
what is you system like.
length of pipe, size....etc.0 -
System
Gravity conversion, WM Ultra 155, continuous circulation on secondary, the standard Taco 11 on boiler loop. Primarily and one secondary loop only.0 -
Is the B&G only 5yrs old??
What died on it, coupler i.e. spring thing inside or is it leaking or frozen. If just a coupler, replace coupler and motor mounts and voila, fixed. If bearing assembly, may be better putting on a Grundfos ups1558fc replacement. Pump will mate right up to the flanges of old B&G. Good luck, Tim ps. don't forget to oil it 2 times a yr, not too much either.0 -
If you replace that B & G, save it. It makes a great boat anchor.
Dave StromanThere was an error rendering this rich post.
A 15-58 would pay itself off in 2 years...
At 10 cents per kwh, a 15-58 on speed 2 saves 1.2 cents per hour compared to s B&G Series 100 each year in savings, on a $100 investment. 1.75 amps vs only 0.70 amps under load. If you pay 20 cents per kwh the savings are $120 a year.0 -
I'm with Dave..
..on that one. Time to update!
Ross0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
