Geothermal retrofit and my dad
Jim Hilpipre
Member Posts: 19
Just simply show him your heat loss/gain calculations and compare to the air handling equipment output you are proposing. (In regards to CFM and water temps the Geo equipment will produce efficiently.)
I normally tell people that I need to be able to distribute the energy I create with a properly designed system or we are both wasting our time.
If you have a flow hood show him exactly the total air delivery volume and show him the difference and let him make the decision.
Jim Hilpipre
Jim Hilpipre
Dad's heat pump retrofit
My dad is great. He was able to put me and six siblings through college while keeping a combination dairy and beef operation profitable. Now that all the "help" has moved on, Dad is thinking about getting out of the Longwood combination oil/wood stove he's had for decades and going with geothermal. I'll try to be brief and thorough at the same time.
His house is a two story 3300 sq ft, 4br, 2 bath home. It was built in 1970 with electric baseboard. It was retrofitted with a simple duct system that delivers 900 cfm to perimeter registers on the first floor and one 4 by 12 register in the middle of the hall on the second floor. I know I can get a supply and a return trunk to the second floor attic and install a distribution system that will service the second floor but I am having a bit of trouble selling all the extra work. I know it's necessary but he is reluctant. Any suggestions?
Also, would there be any gain in having the grey water in the house piped into a trench next to a closed loop for heat exchange?
Darin0
- 120 Geothermal
- 169 Indoor-Air Quality
