Entran Onix
phil_23
Member Posts: 3
Does entran onix by heatway mfg. in 2001 have an oxygen barrier
I believe so
I think the word onix came from "nix the oxygen" Is it black or orange? The current black Onix has an aluminum layer for 100% O2 barrier.Bob "hot rod" Rohr
Living the hydronic dream0 -
Horizontally 100%....
But parallel, there is a small amount of tubing on each gozinta and gozuta that does not preclude oxygen permeation (the inner tube).
Added up, all of these gozintas and gozoutas HAS to add up to a fairly sizeable target for oxygen INgression.
That said, even copper piped system have points of ingression, i.e. packing glands, flange gaskets, expansion tank diaphragms and so on and so forth.
Regardless of whether it has a barrier or not, the water should still be treated and tested on a regular basis. Onix definately has a barrier tho...
Why do you ask?
METhere was an error rendering this rich post.
Email me...I will share..Richard0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
