Anyone have a pic of a finished swing door with flexible oil lin
Bob Harper
Bob Harper Member Posts: 1,100
I suggest you install a Tiger Loop with a Firomatic valve,a vacuum gauge, and Gar-ber spin on filter. From there, you run stainless steel flex lines to the fuel pump. When you open the door, the hoses go along for the ride. If you do not already have soft copper lines, I suggest you use copper coated with PVC and labeled for oil such as Kamco.
