Gorton mains leaking
TimS
Member Posts: 82
A few years ago I replaced the old Hoffmans with Gorton 1s. Last year one of them started leaking late in the season. Now they both leak, one slightly and one about half a tea kettle's worth. They are both on 8" risers. Aside from outright replacement, is there anything I can do to fix and/or prevent this?
thanks,
jim
thanks,
jim
yes
Try boiling them in a pot of water and vinegar. Sometimes that gets them clean again.0 -
I went down today to do this and noticed they weren't leaking from the vent hole, but from where the front cover is pressed onto the housing, at 6:00. If I blow into them while covering the vent hole air spews from the cover seam.
Has anyone else seen this from the no. 1s? Did they have a bad batch?
jim0 -
Possibly
but was there any banging in the system? That can tear steel apart, not to mention brass.....
Hmmm...in past heating seasons I would hear occasional banging, maybe once or twice per cycle, but I couldn't tell if it was inside the pipes, inside a radiator, or just a radiator expanding and the feet snagging on the floor. I did a bunch of corrections at once (re-pitched rads, gliders under feet, rebuilt risers & header) so I can't determine what eliminated the noise.
I did measure the mains pitch and they're fine.
Since I have 2 broken vents and no one else has piped up in accordance, I'll suck it up to my system being the culprit and swap them out.
jim0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
