Gravity circulation?
Mike T., Swampeast MO
Member Posts: 6,928
No, you won't get gravity circulation that way. I have though seen a diagram for a basement radiator with a gravity system. You use the return from an upper floor radiator (2nd or 3rd floor) to supply the basement radiator and then run a dedicated return line from the basement radiator back to the boiler.
Correct me if I'm wrong but,,,
If you have a boiler at ground level and the pipes leave upward,travel across the ceiling and then branch downward to commercial sized baseboard this creates a heat trap and there is no chance for gravity circulation to occur. The system is designed with a supply and return main, not a loop just FYI.0 -
Modern Hydronics covers this...they called it an under-slung return that made a trap and no need for a check there. There was a minimum distance needed but it was not much...
TimJust a guy running some pipes.0 -
Thanks,
someone hit me with "we think the check valve is bad because we're gettin warm pipes when the pump is off" and later I got to thinking, this can't happen, UNLESS there is a connection betweeen supply and return at the ceiling level that I'm not aware of. Must look again.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
