btu,s
Paul_90
Member Posts: 1
How do i figure out how many btu.s i need to heat my house?
Go to the top of this web page
Click on "Resources" then on "Heat Loss Calcs" and follow the instructions.
Essentially you will be measuring areas of exterior walls, glass, doors and roof, all surfaces which define and contain heated space. This will determine transmission or conductance through surfaces.
Then you will calculate volume to determine infiltration or heat lost from air exchange with the outdoors. Pretty much.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
