condensing combi
kpc_36
Member Posts: 21
get wired? ty,kpc
I have read here ...
that you can pretty much turn any boiler into a combi boiler by simply adding a braze plate HX as a zone. How would the wiring be done to have the zone run on a domestic HW call? would the boiler have to mantain temp all the time? I am thinking about doi ng this w/ a Munchkin Contender....any thoughts? ty,kpc0 -
Just talking pumping here
Just remember to size the circ that you use for the plate from the boiler properly. You need to figure for the pressure drop through the boiler, the piping and fittings and the pressure drop through the plate.0 -
WIRING
Well, you can use the DHW priority feature of the Munchkin Contender. It will also put 110volts to the P2 terminal. You would, however, have to put a call for domestic hot water to the DHW sensor connections of the boiler. Please refer to the Vision one diagrams for piping. You may also want to contact your local rep. for the Munchkin Contender.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
