Trane vapor system
Paul_87
Member Posts: 37
Trane vapor system
I am replacing a boiler in a house with a Trane vapor system. My junk guys took the return trap and it's gone. If I install a vaporstat will that eliminate the need for the return trap?0 -
yes
the vaporstat will do just fine..if possible install two stage firing if its a gas burner..that will keep the boiler from cycling on the vaporstat so often.
gerry
how would I do that? The boiler is a Burnham IN9. Thanks
we use maxitrols
two stage regulators and a vaporstat to trigger it..its energized to drop into low fire..we use sr500-1 models alot..our supply house orders them via a rep called metropac. http://www.maxitrol.com/Regulators/2stageregulators.html
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
