Changing from scorched air to hot water question
Bob Bona_4
Member Posts: 2,083
to take out the risers, fishing pex thru sheetmetal ducts is scary. The insides have all sorts of sharp edges, screw points, etc. The humanity!
At the very least use a pex al pex product that stays pretty stable when heated.
I am planning to change from scorched air to hot water and need to know if I can feed the pex tubing from the basement to the second floor through the existing ductwork. If that is not recommended then I am limited to running from the basement up to the attic and then down to the panels in the second floor rooms.
Any other suggestions? I am all ears.
Thanks0 -
I have converted...
both my homes.
The secnd I ran up every interior wall I could and then found a corner to box in to another set. I used 1/2" pex and used panel rads.
rip em out
In my place there were three 5" risers going up interior walls from the main trunk in the basement to the second floor that I disconnected from the boots then yarded on from the basement & dicarded. I then fished 1/2" pex up through the resulting cavities. I don't see any real reason not to route it through the old risers but in my case it was easy enough to get them out.0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 772 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
- 19 Recall Announcements
