he-4 boiler making noise runs hot chills quickly when booster ki
Big Ed_4
Member Posts: 2,992
Will need more info as to the problem.... assuming the unit has a capulary limit . Check the aquastat / limit if it is set too high ,set to 170-180 , if correct it may not be sensing the water temperture. Make sure the capulary is fully inserted in well. Next replace limit.
Clicking sound .... May be related or not. Sounds like a intermiting short or contact. Need to check out electrical circurts.
PS time for a pro for safety sake.
noise
i have HE-4 weil mclain boiler makes loud clunking noise periodically . Has series 100 booster. temp climbs to 230 but quickly declines when booter kicks on. also clicking noise from juncture boxes for thermastats. please help0
- 86.2K THE MAIN WALL
- 52 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 913 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
