One Pipe Steam Counter Flow Questions
Brad White_198
Member Posts: 72
The Hartford Loop may or may not be part of the issues. Think of the Hartford Loop firstly as a "safety seal" to keep water in the boiler should the return line leak.
A Hartford Loop should be installed on all such steam systems with few exceptions. If the boiler manufacturer recommends it, it becomes a code requirement in most jurisdictions. It is good practice regardless.
Secondly, the Hartford Loop can act, in concert with the wet return, as a seal to keep steam out of the return line. (Too often I have seen returns dropping down and connecting to the equalizer in a location that may occasionally be above the waterline, thus allowing steam to hold back any return condensate. A drop and rise would solve this.)
The make-up water usually goes into a wet return, yes.
A counter-flow system would normally have a drop to the return shortly after the main leaves the boiler, to drop off the returning backflowing condensate of course. You probably have this; if not, I cannot imagine how it works without a secondary means of return. Let's assume you have that.
The main vent should indeed go towards the end. Getting air out of the boiler is great, I would leave that as it does no harm, but it does nothing toward getting your main vented. Hold it back at least 15 inches from the end elbow though.
Hartford Loop In a Single Pipe Counter Flow Steam System
I have a customer that has a Single pipe counter flow (reverse flow) steam system, and he has been having some problems. Most of it is air problems, but when I was looking at the piping there was no Hartford loop piped in. But do you need a Hartford loop in this particular system? Also, the water supply should best be installed on the return of the boiler? He also has his main steam vent about 3 linear feet off of the supply main, should I move this to the end of the run? ( about 25' )0
