jim hanknson@ system 3200
Good luck Jim
  • oil246gas
    oil246gas Member Posts: 12
    system 2000 fedder
    well i finally had time today to put that standard ek-1( ihad asked about getting it into a 24" doorway last week) in the basement--started laying fittings and placement of things -- i got the high mass manifold -- thats all in --my question is about the water feeder -- i used the tee in the return for a temp gauge and i want the feeder to go in on the cross tee for the expansion tank --i have to pipe it to drop to the left side of the unit , i want to put the feeder tee'd on that pipe goin to the exp. tank --i noticed this goes to the same place where the unit has the high temp limit though -- i know it will work but would there be any warranty issues --if something happened?? ----we all know that the feeder should be at the point of no pressure change --but i see piping diagrams shwing the feeder going in tee'd with the domestic feed for the water tank - feeding into the return-( that connection is perfect for the return temp gauge )
  • Jim_139
    Jim_139 Member Posts: 61
    Mike
    I sent you a PM.
  • oil246gas
    PM ? i've been on this site on and off for a few years now --i dont see a PM function - i checked my -mail but nothing there - i will be calling tomorrow at energy kinetics --thanks Mike --- oh yeah i can wire and pipe , troubleshoot a 1000% better than i can spell and type --
