Caleffi Zone Valves.
ChasMan
ChasMan Member Posts: 474
No doubt. Interesting valve, the motors are made in the USA.
  • Rick Kelly_6
    Rick Kelly_6 Member Posts: 11
    Caleffi Zone Valve Covers
    I bought some EBV valves and had a few issues with them so I am replacing them with Caleffi valves. Can anyone tell me why they have to be mounted upside down? I mean if you install this valve on the return with the boiler below it and the pipe above the valve cover reads upside down. Thats so dumb. I hope they work well cause they look silly upside down.
  • L'town radiant
    L'town radiant Member Posts: 36
    page three of the tech sheets specifically points out NOT to install the valve upside down. Putting the electrical connections below a possible leak source is a bad idea.
    http://www.caleffi.us/en_IT/Technical_brochures/01131/01131.pdf
  • Rick Kelly_6
    Ha!
    No, your other upside down. The Vertical one not the horizontal if you know what I mean. With the actuator pointing up. It is an approved position. On the honeywells you can flip the cover around.
  • Dave Stroman
    Dave Stroman Member Posts: 765
    We use lots of those type of zone valves. Had a few minor problems but no different the the other brand.
    Dave Stroman
  • Rick Kelly_6
    Upside Down
    Yes, thats what I am talking about. Im just saying, upside down and backwards is no way to go through life.
  • Ted G
    Ted G Member Posts: 63
    Maybe they figure you'll put them on the supply.
