Globe Valves
hot_rod
hot_rod Member Posts: 26,602
multiple speeds, and even delta p, do you even need balance valves? Those old valves sound like just a leak potential.
Have you seen those new autoflow valves. You buy the flow rate you need and pipe them in. No adjusting needed.
hr
  • amhplumb_3
    amhplumb_3 Member Posts: 1
    Question Hard Seat Globe Valves
    Fellow Wallies, what do you think about using hard seat globe valves for balancing loops as opposed to "balancing" valves? I have a system with 3/4" copper series loop system with 4-zones that I am upgrading to P/S using circulators instead of zone valves. I have some ancient yet brand new heavy duty hardseat globe valves that are older then me and I will never use them for anything else! The headloss' that they add is within the flow curve of the circulators. I thought put them to use. Or should I just scrap them and by the balancing valves? These things weigh 3x a same size diameter ball valve!
  • Globe Valves
    Personally I never could see any use for them in a hydronic system, but they may work.
    If within the curve, they will likely add extra velocity noise to your system.
    Dave
